Re: 450D fuel pressure
Posted by brianh on January 22, 2001 at 11:23:58 from (205.188.199.59):
In Reply to: 450D fuel pressure posted by Jon on January 21, 2001 at 16:34:27:
Check and make sure the relief valve in the primary pump is not stuck partially open. If you can check the dead-end pressure of the primary pump without going into the injection plunger it should make 32-39 lbs. Note that there is also a relief valve set at about this amount in the plunger, too, so either one of them sticking open can cause your problem.
Post A Followup
: Re: Re: 450D fuel pressure
