Farmall Tractors Discussion Board
Re: TA problems
Posted by 43 H on January 26, 1999 at 13:52:04:
In Reply to: TA problems posted by Gene on January 25, 1999 at 18:23:19:
Question first. Are you haveing promblems shifting gears in normal or TA ranges if so check your throw out bearing and clutch tension. But if your not having problems shifting check your rear end oil level.
Post a Followup
: Re: Re: TA problems
