Re: IH 574 - good or bad?
Posted by ltf in nc on January 25, 2001 at 17:17:13 from (206.228.213.111):
In Reply to: IH 574 - good or bad? posted by Lenny on January 25, 2001 at 14:39:20:
The following is a copy of my previous post: Both of mine have been very dependable. These tractors come with more than one type of injector pump. Bosch equipped 574s are more valuable as they start easier. These tractors have a multiposition fuel cutoff lever with a start position immediately above the cutoff position. As for problem areas. These tractors will not tolerate poor maintenance of the hydraulic system. Clean filters and fluid are a must. The shift linkage is subject to get sloppy through the levers. The shift lever is dangerously located when dismounting. Your leg can and will cause the tractor to shift out of neutral if you brush against it as you go off. At 52 HP with good weight the tractor is very versatile and will perform. The saddle tanks are steel and I have seen some that are rusted through on the bottom so you will want to check this out. The brakes are power assisted and the master cylinders sometimes will require a couple of pumps when the internal seals leak. Other than minor nuisances these tractor are reliable and therefore the value holds. I only paid approximately $7000 for the one that I bought years ago when it had 50 hours on the clock. I frequently visit auctions and I still see these tractors bring $6000+. Good luck
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
