Tight lift-all pump?
Posted by Bergen on January 26, 2001 at 05:35:46 from (208.132.18.86):
Upon replacing the two gaskets and the seal on my Super H's lift all(not live), I put the lift all back in the tractor. I started the tractor and when I was engaging the clutch, the tractor almost died! The pump was TIGHT! I thought a chip of metal was in between the teeth, so I took the actual pump apart to inspect it. I did find the tip of the screwdriver I used to jam the gear teeth while taking the coupling nut off so I could replace the seal(laughter... a scared sort of laughter...). Anyway, I put the pump cover on and tightened up the eight bolts and still the pump was too tight to move. loosen bolts, try again, same result. tried that a couple of times. the last time I tried that, I tightened each bolt slowly and the gears turned reasonably well, until I got where I wanted the bolts to be and at that moment the pump again tightened or seized up. The pump worked excellent before I replaced the seal and gaskets. I'm thinking that there must be a burr on the bottomside of the gears that is causing the binding, but I became discouraged and didn't want to take the pump apart again, plus I figured you guys could come up with some ideas. Also, is there a specific torque that the pump cover bolts are supposed to have?
Home
| Forums
Today's Featured Article -
Women and Tractors - More Views From the Farmer's Wife - by Teri Burkholder. The top ten reasons why the judges wouldn't let you participate in the stock antique tractor pull: Hey, this is stock! It came with that V8 in it! That "R" on my tires stands for "really old" not radial! Blue gas? We thought it was a pretty color! What wire hooked to my throttle?
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
