Re: Super M clutch linkage
Posted by Haas on January 28, 2001 at 09:08:10 from (129.37.117.45):
In Reply to: Super M clutch linkage posted by Joe Berendzen on January 28, 2001 at 08:26:01:
Don't drive it until it's fixed! That bolt has got to be out of the main drive shaft coupling. That is the shaft between the clutch and the transmission. One half of the coupling is attached to the transmission drive shaft, and the other half is on the shaft that goes into the clutch. I don't know for sure about the Super M, but on the M, 4 of those tabered bolts and metal washers with rubber hold that coupling together. As Bob M said, you should be able to fix it through the opening in the bottom of the clutch housing.
Post A Followup
: Re: Re: Super M clutch linkage
