If the noise absolutely comes and goes when you change the accelerator pedal and changes pitch upwards as speed increases, that's ring gear and pinion howl.
Been working on transmissions since I was a baby and have never heard a noise out of 'em except for a hashy converter sound and there is no doubt about that noise. It sounds like a meat grinder.
I've heard 'em make a light "whine" in lower gears after someone has mismatched the planetary gearsets, but I don't think that's what you are describing.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
