Re: Can't pull a well??? 80 gallons in your pipe?
Posted by LJD on April 22, 2012 at 12:13:43 from (75.250.227.67):
In Reply to: Re: Can't pull a well??? 80 gallons in your pipe? posted by Brian G. NY on April 22, 2012 at 09:31:43:
No matter what - 180 feet of pipe filled with water and pump at the bottom is not going to weigh more then 90-100 lbs. Even a small person can pull 100 lbs. out of hole and that's only when you start pulling. It gets lighter as you pull it up.
There were claims here made that a person cannot pull by him/herself. That tells me the person making that claim has never worked on a well.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
