Re: Ford Tractor Identification
Posted by Mattinglyfarms on September 08, 2013 at 17:48:02 from (12.21.188.3):
In Reply to: Ford Tractor Identification posted by showcrop on September 08, 2013 at 17:35:21:
Showcrop,
Thanks for the reply. I will indeed have to go thru the bolster and it looks like on center I will have only 1" or so above the hump of the bolster to clear to the pulley ->hydr pump. I tried to "eyeball" a hollow piece of pipe centered to my pulley bolt head for a clearance check. It will be close, I was a bit concerned about the 21" splined shaft that would be needed, I certainly can't afford any wobble or alignment issues. If I can clear the hump by an inch or so, do you think the length of the shaft will be o.k. to drive the pump from a hub assmbly off the tractors pulley? I'm confident I can extend the rear frame well enough to reach the axle, but this front drive has me scratching my head a bit!
