Posted by Steve@Advance on August 30, 2017 at 20:01:53 from (66.169.147.211):
Last Saturday I posted about an 06 Ultra Classic that wouldn't idle, appeared to be too lean.
I cobbled together a fuel pressure gauge, sure enough, only about 20 PSI instead of the needed 60 PSI. Also, as soon as the ignition was off, the pressure would fall to zero.
Opened up the tank, pulled the pump up so the pick up was just in the fuel, turned the ignition on. Just as I suspected, spraying gas inside the tank!
Got to looking, the oring on the pressure regulator was blown out. Further investigation revealed the plastic housing the pressure regulator sits in had a broken ear, which allowed the regulator to come out far enough to release the oring.
Must be a common problem, the aftermarket replacement is aluminum instead of plastic.
Replaced the regulator housing, a new filter, a gasket, and some screws, Hundred Dollars (note the initials HD lol) and it's all back together, pressure came up, running good.
Thanks Hobo and others about the cam chain tensioner problem. I told the owner, said we'll go into it this winter and check them out.
Upload one or more videos to your post. Photo filesizes should be less than 300K and Videos, less than 2MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
