Re: Saturday Rust Pic
Posted by Majorman on February 02, 2019 at 05:07:57 from (86.139.72.240):
In Reply to: Re: Saturday Rust Pic posted by kcm.MN on February 02, 2019 at 04:38:16:
Thye Muir Hill was superior to the County in some ways, it had a far better turning
circle. Mind you it was a heck of a climb into the cab. Based on the Ford 5000 originally
with a Ford 2703 E industrial engine. One of our customers had a gear box fail so I was
given the job of splitting it and putting new gears and bearings in it. Had to split it
at the clutch and the rear drop box. Got it all back together and took it out on test
only to find a loud clatter in 4th gear and 8th gear. Could not work out what the problem
was so had to strip it out again. Then found the store man had issued me with the wrong
gears, she had been built just as Ford changed the gearbox in 1968 which had a different
profile on the gear teeth.
If I am honest I liked the County and the Roadless better than the Muir Hill as they were
straight through to the rear axle without the drop box which could give trouble. Muir
Hills are still being built to order.
