Help! Injector pump problem.
Posted by mb58 on March 25, 2019 at 09:18:30 from (192.234.241.107):
Cranked my 1965 Case 1150 dozer Saturday after sitting idle for about a year. When it cranked, the engine is at max RPM's. The throttle had no effect on engine speed. I was told the governor was stuck. Also was told that I could either tap on the inj. pump and if that didn't work, to take a nut out of the end of the pump and there will be a "fuel rail" that is stuck. Tap the rail and it should give control back to the throttle. I need help/verification here. Anyone got ideas or had to fix this problem before?
