Re: Can't get temp. sender out of Ford 801 tractor...
[ View Follow Ups ] [ Post Followup ] [ Return to Tractor Talk Discussion Board ]
Posted by Gerald on December 08, 1998 at 07:12:27:
In Reply to: Can't get temp. sender out of Ford 801 tractor... posted by Herb Wheeler on December 07, 1998 at 19:20:50:
: I have a Ford 801 tractor. I'm putting in a new temperature gauge due to old one was broke. The trouble is I can't get the sender out of the block. Is there an easier way to do this? I have tried vice grips and pipe pliers but it still doesn't move. The owner before rounded the hex head off too much to use a six point socket on it. Any help is surely apprieciated. Thank you for any help. Herb
Apply Kroil from Cano Labs. Let it soak a day, the applyl the vice grips, turn a little in sometimes helps break things loose. If you break it off them drill it with a carefully centered tap drill for the pipe thread and you should be able to get the pieces out and clean the threads with the pipe tap.
Gerald
Post a Followup
: Re: Re: Can't get temp. sender out of Ford 801 tractor...
