Re: Questions About Steel / Buildings....
Posted by MarkB_MI on December 25, 2019 at 19:50:16 from (174.230.20.114):
In Reply to: Questions About Steel / Buildings.... posted by Bryce Frazier on December 25, 2019 at 14:45:20:
If you don't have any sort of building inspection where you live, you can build just about anything you want using just about any materials you choose. That doesn't mean it's a good idea, but you're free to do it at your own risk. Of course if your structure collapses and maims or kills somebody else, you'll find that the courts tend to rule very unfavorably towards builders who endanger others.
On the other hand, if your county does require building permits and inspections, your plan to use those beams will probably be shot down. Unless, of course, you want to have a licensed Professional Engineer sign off on your plans, which will probably cost a lot more than you'll save in materials.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
