Posted by dewy on May 17, 2022 at 19:49:00 from (74.232.36.51):
Boy welding man wasnt kidding,still has not budged....an hobo i saw your pic...what is that center piece bolt goes thru....an i cant get to back of jumper to put bolts in......in this pic the 4in.c channel is bending, should of picked thicker metal,,but the jack seems to of stopped moving,20ton brand new ..an applyed heat while under pressure...so far no go ,im in shock ,i really thought this would do it...help....dewy
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
