Re: want to remove rear wheel weights on a 930 CASE need advice.
Posted by Ron on August 18, 2002 at 12:12:08 from (64.12.104.52):
In Reply to: want to remove rear wheel weights on a 930 CASE need advice. posted by R Wyler on August 17, 2002 at 18:37:13:
Remove all the bolts holdng the weight on but leave the bottom one in ( the weight will stay in place) Loosen the bottom bolt and lift up the weight and remove ( I am not a strong man and I can do it). To install use a motor hoist makes it easy.
Post A Followup
: Re: Re: want to remove rear wheel weights on a 930 CASE need advice.
