Tractor Talk Discussion Board |
Re: Broken Wheel Dish (Centers)
Posted by François on July 27, 2005 at 10:24:44 from (207.253.108.143):
In Reply to: Broken Wheel Dish (Centers) posted by Rod F. on June 21, 2005 at 19:41:42:
This wheel dish is may be in cast iron. To verify this, you can do a spark test with a grinder. If there are only few red and exploding sparks, it is cast iron. If there are a lot of long and yellow sparks, it is steel. If your part is in cast iron, you should use Sodel Cu89 to repair the part (except if the part is oil contaminated, then you should use sodel 352 as buttering layer on the dirty iron and after use Sodel Cu89 to fill the groove). If it is high carbon steel, usually cracking should occur in the hardened heat affected zone (beside and under the weld bead). When cracking occurs in the weld bead, it is generally related to surface contaminants (oil, grease...). Clean the surface (grinder) and preheat the part around 300F (using sodel 330). Slow cooling is also recommended. If it is a free-machining steel (containing high sulfur or high Pb(lead)), it is sometimes impossible to weld... FL (Sodel)
Home
| Forums
Today's Featured Article -
12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
