Tractor Talk Discussion Board |
Re: farmall cub charging system
Posted by John T on November 07, 2005 at 06:22:21 from (66.244.90.98):
In Reply to: farmall cub charging system posted by minifarmer on November 06, 2005 at 20:47:50:
Mini, does it have a working ammeter??? If so what does it show?? If not running and you turn on lights or ignition (if a distributor instead of a mag) if the ammetrs wired correct n working, it should swing over to the - discharge and then if shes working when shes running if shes charging, it ought to swing over to the + charge direction. Or else if it has no ammeter or its stuck, if its charging the lights should glow noticeably brighter form idle to wide open. Thats about the same test Old referred to as placing a voltmeter on the battery. It should read near 6.3 volts setting but rise to 7 or more at wide open if shes charging. Is it a 2 wire cutout relay system or a full fledged 3 wire Voltage Regulator??? Regardless, make sure the belt is good n tight and that the gennys has a good ground and when running dead ground the gennys Field post to case/frame n see if she charges then??? If so but not otherwise, the light switch is bad or not well grounded or the wire from the gennys Field to the switch is bad/open if its a 2 wire cutout relay system, or if its a VR, the Field Control relay is bad or the wires missing from the genny to the VR's FLD post or the VR's not well grounded. This is a start so see what you find n post back n we can go from there. I will then give you more troubleshooting methods as needed. Are you sure the battery is good and capable of taking a charge??? maybe its the problem??? If its charging, the battery voltage will rise at RPM and/or the lights glow brighter and/or the ammeter will indicate charge........... Does the battery always start the tractor or does it run down n need charged now n then?? (must have a genny or battery problem) If it stays up n always starts she must be charging !!! Lemme know Good Luck n God Bless John T
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
