Crawl under it, read the tag and/or see if it's cast iron or aluminum.
Most 1980 Dodge 3/4 trucks used aluminum NP208s - but I've seen a few with the cast-iron NP205s if ordered heavy. My 1969 W200 Power Wagon has the NP205, and so does my 1992 W250 - but it's a heavy 3/4 ton with the Cummins diesel. My neighbor has a 95 heavy 3/4 ton with the Cummins and his has the aluminum NP208.
Doesn't your trans have a PTO door - or is it automatic?
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
