Re: Loud Clutch
Posted by Edpap on April 10, 2008 at 20:44:50 from (74.33.236.203):
In Reply to: Loud Clutch posted by MF294-4 on April 10, 2008 at 19:25:52:
your tractor has a two stage clutch if you are getting a vibration in the pedal when you are slipping the clutch I would think the clutch disk is comming apart.if it stops half way up ( the PTO)it would not be the throw out bearing.
I can get you a clutch if you need one they are alittle pricey some where around $700.
Thanks Ed
