Posted by 135 Fan on August 13, 2008 at 18:28:41 from (24.70.95.205):
I've done it now. I was just casually looking around and ended up buying a truck. It was on consignment at a used equipment dealer. The price seemed good and I could really use a truck. It's a 1995 GMC Top Kick with a fuel injected 366 and a 5 & 2 trans. It was used by a feed outfit until they went to a tandem truck. The only problem seems to be that the steel grain box is rusting out. I need to make it smaller for hauling clay and other heavier materials anyway including a water tank. The speedo shows less than 200,000kms. The front tires are like new Bridgestone radials and the rear tires are probably about 50% or better radials. Cab and body is in excellent shape but the windshield is cracked. I think it's a one owner truck but not positive. It does look like someone took care of it. I paid $5500 for it because anything with a gravel box was a lot more money and usually a lot more abused. It has a 2 cylinder hoist that doesn't appear to creep down. The owners manual is still in the glove box! Can you truck guys tell me if there's anything I need to be concerned about with this truck? It has an 11,000 lb. front and 19,000 lb. rear axle with hydraulic brakes. The truck will mostly if not always be used just on my land without a lot of road travel. Any input is appreciated. Thanks. Dave
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
