Tractor Talk Discussion Board |
Re: John Deere M clutch problem
Posted by Jason - Senoia, GA on October 17, 2000 at 21:10:36 from (209.86.132.73):
In Reply to: John Deere M clutch problem posted by Jim on October 14, 2000 at 15:13:12:
Jim, I have a JD 40 that developed the same problem. The collar that holds the throw-out bearing behind the pressure plate is where my problem originates. It has partially detached from the clutch rocker arm that goes thru the bellhousing horizontally and will occasionally bind on the engine output shaft to the transmission. It was only an annoyance for a while because I could double-clutch and make it disengage. But it got worse and it is hard to stop that chugging two cylinder when you get to the front of the trailer you are loading it on and push the clutch and it starts to climb over the front of the trailer. I am planning to split mine in two as clooney described. It's not a very bad job.
Home
| Forums
Today's Featured Article -
Product Review: JB Weld - by Staff. JB Weld is basically an epoxy glue that does an exceptionally good job of bonding to cast iron and steel along with several other materials. As I mentioned, it is so common that I have yet to buy a tractor that did not have JB Weld used somewhere. It is sometimes used so well you can't tell its there and other times used as a sloppy quick fix. Finding where and how it can be used correctly is key to whether you are using it as an "inelegant hack" or an integral solution to difficult and expens
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
