Posted by Dan-IA on July 21, 2009 at 20:55:03 from (75.252.147.22):
My Spra-coupe just started demonstrating odd behavior with the clutch and tranny. It has a VW industrial engine and transmission in it.
First I thought that it was just hard to shift. Closer inspection noticed the clutch cable was badly frayed, so I assumed the hard shifting came from not having the clutch fully disengaging. Adjusting the clutch cable shorter seemed to help.
It became difficult to find 1st and 2nd gear, so I adjusted the mounting bolts on the gear shift lever. This is just a ball joint that attaches to a shifting rod that goes back to the transmission.
I ordered and installed a new clutch cable, but the new cable is not the same as the old one because of a service update. The new cable has a vinyl block that bolts on at one of the former clutch cable clamps. Adjusting the new cable to remove the free travel went to the limit of the adjustment on the new cable (the nut is screwed all the way on.)
With the new cable tightened as much as possible, if you attempt to start the sprayer in gear with the clutch down it moves, suggesting the clutch is still not releasing.
I don't know anything about transmission work. What should I do now? Any advice is appreciated!
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
