-h- serial number
Posted by mr foote on January 30, 2001 at 18:05:07 from (209.163.3.13):
will some one tell me if there is two serial numbers on a -h- farmall. if so where i could find it,found one on bell housing under gas tank on left side , but where is the one on the motor. inside or out side and are the two numbers the same . the on on my bell housing is not in your registration form on yesterday tractor this is the number - h - bfh 332143X1 thank you i do like your site.
Post A Followup
: Re: -h- serial number
