SMTA TA
Posted by Dan on February 04, 2001 at 14:50:54 from (12.18.161.164):
I have a SMTA with a non working TA. Works fine in the high range just not in the lower one. I see a lot of these advertised with "bad TA" so I am wondering if this is a common problem. If I don't fix it is it likely to start slipping in high range? I have seen kits to eliminate the TA but don't know if they are any cheaper than fixing the TA. Also see heavy duty TAs advertised for these. If this is a common problem is the heavy duty the way to go? This will be used as farm tractor, will not be used a lot on heavy loads. I have also seen adds for heavier parts to put in a regular TA. Is this the way to go? Don't know how expensive it is to overhaul the Ta, see rebuilts for about $400. Since this is my first experience with IH with the TA am relying on all your years experience. ONe thing I notice on this tractor is the platform seems a bit small when you have th live PTO lever on one side and the TA lever on the other.
Post A Followup
: Re: SMTA TA
