Re: Re: Re: What makes a gas engine run rich
Posted by dick on March 03, 2001 at 10:41:34 from (63.120.111.98):
In Reply to: Re: Re: What makes a gas engine run rich posted by Gene on March 02, 2001 at 21:52:45:
Sounds as if you've done about everything but whatever it is that's required to fix the problem. In your comments below, you indicate that your carb. doesn't seem to have a main fuel adjustment, just an anti-dieseling solenoid. Too much fuel flow has got to be your prime suspect since you're getting black smoke, strong gas smell, etc. There has to be some sort of restriction on the incoming fuel other than the solenoid valve. Most IH carburetors have a main screw - do you have an operator's manual for this tractor? If so, it should have a section about adjusting the carb. If not, buying a manual would surely seem like a low-cost option to all of the other things that you've done. Chances are about 99 percent plus that your problem is in your fuel supply control somewhere. At this point, I'd suggest you again try operating for a while without the air cleaner hooked up to the carb. - too little air flow through it is about the only thing other than fuel supply control which would cause the severity of the problems which you describe. If the problems don't magically go away without the air cleaner hooked up, the problem is almost certainly in the fuel supply control. Good luck, and let us know how you progress.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
