Re: 350 drawbar vs. 3 point
Posted by JohnIH on March 30, 2001 at 04:53:16 from (208.169.39.209):
In Reply to: 350 drawbar vs. 3 point posted by the new guy on March 29, 2001 at 18:16:30:
New Guy,
I guess the decision you will need to make is do you ever plan to use a pull type implement with your 350 such as a disc? My 400 does not have a drawbar any more so I have to use a drawbar adapter plate between the lift arms to use my disc. To keep the adapter plate from spinning when I back up I had to weld ears on the ends. Before I did this I was breaking pins like crazy. Also the 3-point sway is not desireable either with a pull type implement. Your decision.
PS. My 3-point is double action so if I am not careful it is easy to lift the rear wheels off of the ground in the down cycle.
JohnIH
Post A Followup
: Re: Re: 350 drawbar vs. 3 point
