Posted by MattW85 on June 15, 2019 at 11:34:54 from (174.255.2.136):
Hi, I got a International B275. I'm having a problem with the 3pt hitch. Right the lower lift arms sit on the ground with the 3pt all the way lowered. The problem is that to hook anything I have to raise the 3pt hitch almost 1/2-3/4 the way up to connect the pins. Once hooked up I can only lift most things only 4-5" off the ground before the upper lift arms reach thier max height.
Any ideas? I have a feeling the upper lift arms need to be took off and rotated to give me more lift height.
Upload one or more videos to your post. Photo and video filesizes should be less than 8MB. Formats allowed are gif, jpg, png, ogg, mp4, mov, and avi. Be sure to use filenames without spaces or special characters, and filetypes of 3 digits lower case.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
