Re: C front transmission seal
Posted by gene b on April 09, 2001 at 20:37:47 from (63.42.174.65):
In Reply to: C front transmission seal posted by Haas on April 09, 2001 at 19:05:57:
I split them at the trans the seal is easy to do check the journal at the seal if it is worn you might want to use a speedy sleeve over the journal so the seal will seat on the proper size dia
Post A Followup
: Re: Re: C front transmission seal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
