Re: Re: C front transmission seal
Posted by Dave T on April 10, 2001 at 12:17:11 from (63.27.107.168):
In Reply to: Re: C front transmission seal posted by gene b on April 09, 2001 at 20:37:47:
Does this same procedure apply to the Super C. I have the same problem, but not as bad as Haas. As a matter of fact, it would not have been a problem, but I changed the tranny oil.....that heavy tar wouldn't drain thru anything. My T.O. bearing was worn .150", which probably helped to ruin the seal....Question is, do you have to take tranny cover off, and drain tranny to do the work????/ thanx....Dave
Post A Followup
: Re: Re: Re: C front transmission seal
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
