Checking cam gear
Posted by SMTA on May 23, 2001 at 07:13:20 from (12.18.158.25):
Inquired a few days ago about a possible engine problem and got lots of good responses. One the possibilities is that the cam gear is loose or the keyway worn. Is there a way to check this out short of pulling the hydraulic pump and distributor? If that is the problem, I assume the next step is pulling the radiator and going into the front of the engine. Do you have to take off the whole front end to get the cover off or just radiator and steering shaft?
Post A Followup
: Re: Checking cam gear
