Re: electrical system on 464
Posted by Bob M on May 24, 2001 at 06:08:51 from (192.232.119.194):
In Reply to: electrical system on 464 posted by Gene on May 24, 2001 at 00:45:07:
Gene - When you measured the voltage at the coil was the motor running, or did you have it stopped and just the ignition turned on? Reason: When the motor's running, the coil alternately sees 12 volts then 0 volts with each closing and opening of the points. Your voltmeter will "average" these rapidly alternating 12 and 0 voltages. Hence a meter reading of 7 volts across a 12 volt coil with the motor running is just about right.
If the coil doesn't get hot to the touch after running 10 minutes or so, chances are good your coil is the rignt one for this tractor.
Post A Followup
: Re: Re: electrical system on 464
