Re: Water pump rebuild for a M
Posted by The Red on May 24, 2001 at 07:57:07 from (206.246.187.2):
In Reply to: Water pump rebuild for a M posted by Max on May 24, 2001 at 07:39:00:
Max I have rebuilt several H waterpumps. The M is similar, just slightly larger. I would take it apart first and assess what you need. Ken Updike can get any part you need. 608-455-2411.
Generally about the only thing I have replaced is the grease seals in the hub. If it has been greased through the years, the two ball bearing assemblies will probably be fine. When you pull the impellar out of the water pump base, check the brass bushing at the base of the pump casting. You might have to replace it if the impellar is wiggling in that bushing.
Post A Followup
: Re: Re: Water pump rebuild for a M
