Re: Re: Water pump rebuild for a M
Posted by Max on May 24, 2001 at 12:31:03 from (205.188.192.37):
In Reply to: Re: Water pump rebuild for a M posted by The Red on May 24, 2001 at 07:57:07:
Thanks to "The Red", your answer sounds about like my symptons, I think I can use this to fix it
Post A Followup
: Re: Re: Re: Water pump rebuild for a M
