Re: Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Posted by Gene on May 27, 2001 at 18:33:28 from (205.188.199.28):
In Reply to: Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness posted by Red Dave - Bob M. what do you think? on May 27, 2001 at 18:04:07:
Red Dave:
What can I say ?? Jeez, I thought that those reads made no sense at all. Shows how little I know about what I am looking at ! I went back out and checked them again, then, without the jumper on, I pulled the coil wire out of the distributor cap, held it about 1/2 inch or less from a ground, and it had a puny, yellow spark that you could hardly hear. Then, per your instructions, I put the jumper in place between the switch and coil, tried the spark again, and that sucker was blue, arced easily at 1/2, on out to about 3/4 of an inch, and sounded really healthy !! It started up a lot easier when I left the jumper on and I can't explain how dumb I feel about the whole ordeal. Maybe the days of gagging on gas fumes from partially burned mixtures and fouling plugs are over. Thanks many, many times over. Hope you have a wonderful Memorial Day !!!!
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: Possible voltage problem w/coil w/res + res. wire in harness
Today's Featured Article - Tractor Profile: Allis-Chalmers WD45 (Gas Version) - by Staff. Beginning production in 1953, the WD45 had the same general look as the WD tractor which was produced earlier - but was much more powerful. This was due to the new 4-cylinder "Power Crater" gasoline engine with a 4 x 4-1/2 inch bore and stroke. Some people feel this was one of the most significant tractors offered by Allis-Chalmers in those days. Nothing in its weight or power class could match its performance. In 1954 they began offering the WD45 with the new "Snap-Coupler&quo ... [Read Article]
