Welding a Farmall H flywheel
Posted by modelbjd on June 14, 2001 at 19:30:51 from (206.72.4.86):
I am installing an IH 203 combine engine into an H Farmall. I cut the center hub out of the combine flywheel with a bi-metal hole saw and had the H farmall flywheel milled out at the machine shop for the hub to fit. ( press fit of .003 ) What kind of welding procedure do I need to use to weld the hub into place? The machine shop said that they did not do any welding.
Post A Followup
: Re: Welding a Farmall H flywheel
