Re: IH 300 Governor Surging (Galloping)
Posted by The Red on June 16, 2001 at 14:16:31 from (12.75.197.84):
In Reply to: IH 300 Governor Surging (Galloping) posted by Doug Kervin on June 16, 2001 at 13:08:18:
Doug you may have already done this. Remove the governor side plate and spring. Make sure that thruster bearing that moves horizontally on the shaft has no wiggle in it. If it does, that is the culprit on the wavering RPM. If it is solid then we'll have to put our collective brains together and try to figure this out.
Where the governor shaft inserts into the carb. butterfly notch, is there any play in there by chance?
Post A Followup
: Re: Re: IH 300 Governor Surging (Galloping)
