Stumped on C problem
Posted by FC on June 25, 2001 at 07:13:57 from (208.14.16.15):
Ok guys, I don't know what to check next. Here is sequence of events up till now. Would not start, appeared to be dead coil (had no secondary voltage from coil) Replaced coil, and fired off fine Ran fine about 20-30 minutes, then died as if switch was shut off Restarted, but needed partial choke to run well at all Checked fuel flow to carb, seemed ok Pulled carb (twice) and cleaned, checked well and found no problems. Pulled distributor, advance was gummed and looked to be sticking Cleaned distributor, and replaced springs on advance, lubed weights,etc, filed and set points to .020 Restarted, but still surges at lower throttle, runs better at higher throttle, but not up to par with what it should be or was. Timing changes will allow better idle, but not right. I am now beginning to wonder about the new coil I put on. Anyone seen a coil cause this type problem? Points, condensor, cap, rotor, carb rebuilt about 30 working hours ago, and was running fine. I believe the surge is from engine nearly stalling, and governor opening then tractor fires back up with higher throttle then cycle starts over again.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
