Re: Re: Lo-Boy
Posted by Brian on June 26, 2001 at 06:37:46 from (63.67.120.220):
In Reply to: Re: Lo-Boy posted by Bama Binder on June 26, 2001 at 06:16:03:
HI Bama,
With the engine running and the clutch depressed, the engine does not bog down. Only when I let the clutch out. Even if the tractor is in the neutral position, it still bogs down when letting the clutch out. The tractor does not move at all.
I do have the IT manual, but of course it doesn't give much 'hints' or 'tricks' when dealing with this. The manual says: "try to identify the problem before disassembling transmission to far". So I am hoping it may just be an easy fix.
Obviously this tractor had done this numerous times before I got it. It wasn't locked up when I loaded/unloaded it, but when I was rebuilting the motor, I 'rocked' the tractor back and forth in every gear to check things, and now it is locked up.
Thanks, look forward for more information.
Post A Followup
: Re: Re: Re: Lo-Boy
