Re: Farmall C skipping a beat
Posted by FC on July 02, 2001 at 13:01:24 from (208.14.16.15):
In Reply to: Farmall C skipping a beat posted by Haas on July 02, 2001 at 04:09:53:
Probably not the culprit, but I had a similar problem with my C, and discovered a broken screw on the throttle blade which let the blade misalign and hang slightly. Drilled out screw, and replaced using Loctite threadlocker. I was lucky the blade never came completely loose on me and into the intake, etc.
Post A Followup
: Re: Re: Farmall C skipping a beat
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
