Re: 3pt raises/lowers too fast
Posted by rhudson on July 24, 2001 at 09:35:56 from (63.81.99.149):
In Reply to: 3pt raises/lowers too fast posted by jmyt_47 on July 24, 2001 at 09:27:57:
Hi jmyt_47 ,
you will need a hydraulic manualy adjustable flow control. if the pump does not have a pressure relief valve, you will need that also. if you will post cylinder diameter, stroke and time you want for full stroking of cylinder, i'm sure someone will spec. the valving for you. surplus sales good source for well made fairly cheap parts. northers good sorce for cheaply made, fairly expensive parts. i'm quessing you don't have a belly pump on your H?
Post A Followup
: Re: Re: 3pt raises/lowers too fast
