Re: Re: Farmall M with hand clutch
Posted by Steve in PA on August 02, 2001 at 03:24:17 from (63.20.230.101):
In Reply to: Re: Farmall M with hand clutch posted by John C on August 01, 2001 at 19:29:15:
John
The hand clutch will not make the liftall live. My
recently purchased M has the hand clutch but
also a M & W power steering unit that makes
the liftall live. This unit is just mounted ahead
of the steering column. The live hydrualics
come from another part of the steering that is
placed ahead or in front of the distributor. The
plumbing goes something like this--I have
often wondered if it was correct! The high
pressure is generated at the pump at the
distributor, to the unit on the steering column,
to the liftall and returning to the distributor. It
works great! As for the value of the M at
auction, bad tires, bad paint, looks leftout in
the rain more than ever having a roofover its
head-$500 max. An average M around my
parts -$1500 max. Also consider what use you
will give it. I mow 15 ac.of rotation pastures
plus a spreader. I would not be without the
power steering. With the dead furrows around
here, we call M's w/o ps arm breakers. Wish
you well,and much enjoyment. Maybe post
what it went for? Steve in PA
Post A Followup
: Re: Re: Re: Farmall M with hand clutch
