Re: help with bucket on H
Posted by Scott on August 09, 2001 at 07:31:59 from (24.149.18.59):
In Reply to: help with bucket on H posted by shan on August 09, 2001 at 06:31:09:
Shan, I have an H with a trip bucket loader. When I got it, I had the same problem with the bucket lowering too fast.I use one way cylinders, and am plumbed from one port on the belly pump. The same port eithor supplies pressure, or acts as the return. I installed a flow control valve here that controls flow in both directions, this way I can easily adjust the raise and lower speed for different uses. As for why when hitting a bump the loader drops, I don't know. Mine has done that too. Maybe someone can enlighten us.
Post A Followup
: Re: Re: help with bucket on H
