Re: Charge it, please...
Posted by Bob M on August 13, 2001 at 12:51:05 from (165.170.128.65):
In Reply to: Charge it, please... posted by HavinFuninMo on August 13, 2001 at 11:50:02:
Changing to positive ground is straightforward:
1 - Remove the cables from both battery posts.
2 - Swap the wires at the two ammeter posts (or you can ammeter wiring as is - it'll just read backward if you don't swap the wires)
3 - Install/connect the new regulator.
4 - Reconnect the battery with the POSITIVE post grounded.
5 - Polarize the generator: Momentarily connect the BAT and GEN terminals at the regulator.
You now should be set to go...
Post A Followup
: Re: Re: Charge it, please...
