Re: Live hydraulics for a H????
Posted by Jim on August 22, 2001 at 04:03:45 from (12.36.154.2):
In Reply to: Live hydraulics for a H???? posted by Zonie on August 21, 2001 at 23:21:39:
You can do it a couple different ways...
1. You can put on the pump from a 300 but you have to change the timing cover, or
2. You can find an M&W live pump made for the H.
I have an M&W pump and I love it. I use the belly pump's casing for the resevoir (I took the pump out and put a plate over the casing).
Good Luck !
Post A Followup
: Re: Re: Live hydraulics for a H????
