Re: Re: RE: Farmall H clutch pilot bearing lubrication
Posted by Slappy on August 31, 2001 at 04:37:59 from (143.88.58.77):
In Reply to: Re: RE: Farmall H clutch pilot bearing lubrication posted by The Red on August 31, 2001 at 04:17:51:
Red,
The clutch release bearing tube was broken off but I have replaced it and the hand hole cover with the swinging grease hole cover, so no problems there. The pilot bearing fitting I'm refering to is shown in the manual to be forward of the release bearing and located on the flywheel itself as near as I can tell form the drawing. There is a permenent opening that is not covered by a grease hole cover, forward of the clutch housing hand hole cover. I can clearly see the flywheel edge through this hole in the housing, but no lubrication fitting. Any other thoughts?
Post A Followup
: Re: Re: Re: RE: Farmall H clutch pilot bearing lubrication
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
