Re: Super A burns oil
Posted by Ralph on October 04, 2001 at 11:28:22 from (209.254.185.79):
In Reply to: Super A burns oil posted by Dan M on October 04, 2001 at 11:14:58:
Dan M: You'll get various comments on what to do just as much as asking what type of women to marry.(ha) If it does NOT smoke too much and has enough power for mowing, keep using it. How low does the oil pressure get? It is common to have low pressure when hot and at low RPM. Two common things that contribute to this are poor main bearing(inserts) and an oil pump that is worn\warped. Its easy to put in main bearings and rework the oil pump.. but unless its real bad I'd wait for a more complete rebuild time. I'd also say I'll agree with your choice of nondetergent and 30 wt. Now for other views.. ralph
Post A Followup
: Re: Re: Super A burns oil
