Farmall Tractors Discussion Board
Re: 4X4 vs 2 wheel drive
Posted by carl on March 06, 1999 at 12:21:39:
In Reply to: 4X4 vs 2 wheel drive posted by Steve on March 06, 1999 at 09:38:03:
I also live in WNY. I have a MF 274 4wd that will go through alot of mud and snow. I use it in the summer on wet hay ground because it doesn't sink in the mud and leave tracks like a big tractor would. In snow not only does the front tires pull they dig a path for the back tires where a 2 wheel drive's front tires just drag extra snow. The downside is the front tires seem to wear out quickly and are alot more expensive. It doesn't turn very sharp and is almost impossible to back up hay wogons with it. I think that the pros outway the cons though
Post a Followup
: Re: Re: 4X4 vs 2 wheel drive
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
