New Rod Bearings didn't work!
Posted by Dick Davis on October 25, 2001 at 11:43:23 from (64.12.105.39):
So I need to get the crank ground, don't suppose it can be removed in frame? If I pull the engine out forward where does it disconnect from the clutch? Is it a splined shaft? Can't quite figure it out from the IT manual. Thanks for any suggestions. I'm in over my head again. Dick
Post A Followup
: Re: New Rod Bearings didn't work!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
