Re: How do you changing a starter ring gear
Posted by Paul Shuler on November 12, 2001 at 18:35:56 from (207.150.31.66):
In Reply to: How do you changing a starter ring gear posted by Michael on November 12, 2001 at 17:47:05:
third party image
Use lots of heat. I thought I would just heat mine a little and wack it off there. Big mistake. Cracked the fly wheel. Ok I will admit it, that was stupid not to mention not very cost effective.
Post A Followup
: Re: Re: How do you changing a starter ring gear
