Re: H radiator removal/rod bearing size
Posted by Farmer Bob on November 18, 2001 at 21:59:22 from (66.152.73.85):
In Reply to: H radiator removal/rod bearing size posted by Larry on November 18, 2001 at 20:10:28:
Larry, The steering shaft does come out through the hole in the upper front bolster. Unscrew that big cap on the front which will allow the shaft bearing to pass through that hole. First, loosen the collar on the front side of the steering support post under the throttle lever. Using a large screw driver or punch and a lot of penetrating oil, you should be able to push the rear steering rod back enough to separate it from the front shaft. Grab the front shaft (May have to use a vise grip or pipe wrench) and turn it out through the front bolster. As far as the rod bearings go, I would recommend you have the crank journals measured to ensure you get the correct bearings. You may also find one or more that are worn indicating the possible need to have the crank turned. How did the old bearings look when you removed them? Any worn/shiny areas? This would indicate an out-of-round crank journal. As long as you are in there you may as well check/replace the mains as well.
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
